RE: Tiny Tomboy build
Here's another one by Mr Smeed you might want to consider, a Madcap, except this one is the Mini-Madcap. I've posted a pdf using the txt file trick: You change the PDF to TXT and then you can post it. I saw this used before and it works pretty well.
chuck
