RE: ........... BELT CP V2 Thread..........
I just went through 1 battery pack at 1/4 throttle. Used wood plank & bricks to hold it down. I wanted to check on battery, motor & ESC heat. I ran it for about 15 to 20 minutes striaght and I found the ESC got about 100 degrees (I could touch it no problem) but the motor was real cool.....I did notice the gyro warmed up a little too. The tail servo doesn't center properly once I apply left yaw. It centers back from right yaw and it centers back when I apply multiple yaw. Just if I apply left yaw only and stop. I'm not overly concerned it's not like it doesn't center at all, but I will probably replace the tail servo with a spare EK2-0508 I have which was for my lama v4.
