RE: Baja Pro-line reed & DX3s rpm/mph gauge install :)
just a word of warning, you might have a bit of a problem with your piston ring breaking as you have removed the ring compression stub in the intake port, all the top porters leave it there for a good reason as the intake is so wide the ring can be slightly un round as it moves thru it and it needs guidance before it hits and snags the top of the port.
