Lets start the fuselage!
The BuckShot fuselage has been designed to be almost warp proof. It has a flat bottom in order to take advantage of a flat building surface. The fuselage design also includes locking tabs to insure straightness in addition to making it easier to assembly.
Remove all laser cut fuselage parts from their sheets. Glue the 1/16 plywood doublers to the balsa fuselage sides at their proper location.
NOTE: Make sure you make a right and left hand fuselage side.
