RCU Forums - View Single Post - making servo bays
Old 02-23-2009 | 11:17 AM
vicman's Avatar
vicman
My Feedback: (10)
Default RE: making servo bays
You just showed the simple easy way for sure.
For a first timer I would go this way too. Also you should consider using shrink tube or other method to keep the servo wires connected to the Y harness or extension wires. You can buy some connector boxes that keep them togeather but they seem to be a little bulky to snake thru the rib holes after the wing is covered. I usually use shrink tube.
