RCU Forums - View Single Post - CA glue question?
Old 02-26-2009 | 05:50 PM
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: CA glue question?
ORIGINAL: LuftwaffeOberst
ORIGINAL: Ram Jet
ORIGINAL: jayjast
This maybe a dumb question but, is CA the same as super glue?
Yes, and if you want my opinion Locktite Super Glue with the brush applicator is the best. $2.97 for .18oz - ouch! It's worth it. I build plastic static models and have for years. I have tried every super glue (CA) under the sun. Locktite is my favourite. With the brush applicator you eliminate the problem of the glue tip applicator getting plugged. I used to use a needle or pin heated red hot to open the hole in the applicator. If you need to apply small amounts stick a pin in the eraser end of a lead pencil and dip it in the glue. The Locktite brush dispenser bottle will accept the diameter of the pencil and away you go. Locktite remains fairly flexible unlike other brands. I recommend that you stay away from accelerator if you want the strongest bond. What's a 2 or 3 minute wait anyway.
Bill
Yes, I won a few Fine Scale Modeler Shows too back in the 90's. Bet you can't guess what type of planes I built and competed in? I used Locktite a few times with a toothpick for my applicator... it works well with plastic models and I used Elmer's white glue as a filler. Then one day I tried ZAP and I was hooked!
Use the good CA glue like ZAP, Great Planes or Mercury Adhesives etc. It has a slightly different formula and it absorbs into the wood better than the off the shelf super glues. Plus you can't get Super Glue in different thickness. It makes it easy to glue in the CA hinges if you use a thin CA with a long thin applicator tip.
I use a Medium CA glue for all the non- high stress area's... like applying detail, adding a antenna to a Warbird etc.
Hope I helped.
Humm, let me guess.............P-51, Spitfire, Hawker Hurricane, and maybe the P-47.................right??
