RE: Saito 115 cam lubrication
This may be a repeat on ALL my 4 strks OS ASP Saitos I PULL THE CAM COVER and put in some grease ditto with the valve covers then give a shot of oil into the nipple on the crankcase BEFORE STARTING a dry start (no lube) will put a lot of wear on the engine in minutes If the engine producers did this they would save a lot of warranty issues beside the headache of sending in martin
