RE: Badius Owners Club (CONTINUED)
Export,
Thanks for the come-back.
I need to know the right method to measure the wattage of a brushless motor that has no documentation.
I've bench mounted it withan 11.1v lipo, 18a esc, prop installed, using an Astro Flight 101 meter.
Do I use the amps and loaded voltage at maximum throttle or do I use only the max throttle amps and 11.1v. My voltage under test always goes less than 11.1v.
When I use the power details of the featured planes in two copies of FlyRC, the max throttle voltage always comes out to 10.9v. I don't understand something.[sm=confused.gif]
Thanks for the help, ConRman[8D]
