RE: Aurora 9 radio
These prices are for the Transmitter and receiver only on 2.4Ghz. A synthesized 72mhz version (Tx,RX)will also be available for $399.99.
The Aurora is module based so it can use Hitec 2.4 and 72mhz (with Spectra Pro module) as well as all other manufactures FM receivers. Also since it is capable of PPM (FM), it will allow the use of other brands 2.4 module/recevers.
2.4ghz receivers are only compatilbe with the same brand module. So if you wanted to use Futaba FAAST receivers with the Aurora, you would need to install the FUtaba FAAST module.
Mike.
