RE: Rolling with hard elevator on Yak 102
What method did you use to ensure both elevator halves were matched? Have you checked incidence of every surface? One major reason that you dont see any problem while 3D is because the wings are already stalled. I would NOT touch the leading edges. Does the same wing drop if you try negative input?
