Hi Gorehound,
I am doing exactly as you have at the moment........drilled extra holes a third extra round
to increase tension..........it does work.......as for the gearboxes, they will fit if you grind off the
front panel near the sprocket a touch and raise the gearboxes up to the correct position.......this part of the Jagd is still quite wrong in my view......I have bee nconcentrating on correcting the fron angle and gearboxes and am nearly there.......will post pickies soon.......
Cheers
CaptB
