RCU Forums - View Single Post - HL Jagdpanther Suspension - Found the problem, Now to find a cure.
Old 03-07-2009, 07:29 PM
Panther G
Default RE: HL Jagdpanther Suspension - Found the problem, Now to find a cure.
I still believe it would be possible to add a spring in side the hull to a lever attatched to the suspention arm. You could actually connect the spring to the gearbox it self. i'll do a mockup on and old panther hull I have and see what turns up.
