RE: Old 3.5 K&B outboard setup help
His motor does not have the CAL mod. It appears the motor is from the 80's or earlier that used the short skeg lower. Someone cut the cav plate off (hence the water pick up pointing forward) and then just opened up the exhaust ports.. Bet it's a loud one!
