RE: a question about my temp???
Of coarse you would take your temp then think if its ok for that outside temperature and humidity and all that!!! Buts its always better to check for perfomance and the stream of smoke coming out of the pipe. THe temp just gives you a safety net in some way. Yeah adam, i would change your front a arms to rpm, caster block to aluminum
