RE: How well does CA glue work?
Tamiya's plastic cement will work on most 2A6 parts which offer the obvious benefit of slow drying hence allowing adjustments after attachment. CA glue is a MUST on some though like parts B6 which hold the return rollers. Unlike most Tamiya releases where a screw holds a similar part from inside the metal chassis, the 2A6 rollers are held by glue alone.
