You are gonna love the boat! Will the hard pack lipos physically fit in it? I use Flightpower 5000 packs and they're a tight fit. Run it first with the stock motor. You will be surprised. It's 2000+ KV. I'm not sure the Ammo is going to give you much more. I run mine with the grim 40x52 3 blade. It is on rails! Just placed 4th out of 16 in the LSH class at a race this past weekend running against some real salty dogs that are nationally known.
ORIGINAL: S!N!ST3R RC hObbys
Hello all, I just bought a white UL-1 with 2 SMC Hard pack lipos 28c 5000mah batterys
for it, new Grim lifter prop, 55mm pitch, and the ammo 2300kv motor to slap in this bad
beast...can anyone say that it will run around 48-50mph??? Im hoping this boat stick to the
water in turns, does it handle mild wind or wake?
