RCU Forums - View Single Post - Project MFD..............
Old 03-21-2009 | 10:12 AM
  #46
Guillermo Ibanez's Avatar
Guillermo Ibanez
Default RE: Project MFD..............
ORIGINAL: marc s
Just started on these units last night. Stripped the cases off and loaded up some images just to make sure things were looking OK.
There are two connections required, one is the power feed the other is the momentary contact switch which fires the unit up and launches the 'slideshow'. The battery connection is simple enough but the switch connection requires very small soldering iron work, fortunately a friend has some equipment at work so he will connect these up to fly leads which can go to the switches destined to be mounted on the equipment board under the side hatch.
Took a couple of poor photos last night, more will follow as the project progresses.......
marcs
Hi Marc:
Are those the coby key Chains?
I just received two of them and are going to start testing them.
Can you send me the pictures you upload in the units to start the slide show? Are those .jpg images?
Here are my pictures. Al have already finished with the air system set up
ID:	1162520   Click image for larger version
ID:	1162521   Click image for larger version
ID:	1162522   Click image for larger version
