RCU Forums - View Single Post - DA-85 Question
Thread
DA-85 Question
03-23-2009, 09:29 AM
10
Cyberwolf
My Feedback: (
4
RE: DA-85 Question
This is what I did to my DL-50 in my Yak I soldered the original hole shut then redrilled a new hole in the center and tapped it 6-32 then used a standard nipple I picked up at the LHS. I then ran the line inside the fuse and made a loop then put the end inside of a pill bottle. The opening in the lid of the bottle is not tight on the tygon as you can see, that way no vacuum can be formed. You can also use a piece of brass tube and solder than on also then drill a hole in the plate. Just make sure there is nothing on the inside that will hit the diaphram.
I hope this helps .
Reply
Like
Cyberwolf
View Public Profile
Send a private message to Cyberwolf
Visit Cyberwolf's homepage!
Find More Posts by Cyberwolf
View iTrader Profile
