RE: Rom air retracts manual requested
Ron, I tried your method for removing the end of the cylinder and it worked fine...Thanks. The nose-wheel cylinder is leaking air between the square end of the cylinder and the rod that connects to the piston and gear. the O-rings appear ok and I cleaned and applied silcon grease to both. The leak is only when the gear is in the down position, which make sense since that is when the high pressure is on the rod side. I does not appear that there is a seal or sleve between the end place and the rod...strange. Have you run across this before? Any advise from anyone will be appreciated. Don
