Commercially manufactured arming plug?
G'day Guys,
Does anyone know if a commercially manufactured arming plug/pin set-up is available for electric pattern models?
Here in Australia most, if not all, electric pattern models use a Deans connector glued to the side of the fuse. I have a couple of concerns with this technique firstly because the Deans connectors are only rated to about 50 amps and secondly the insertion and removal process must put a lot of strain on the fuse side.
What are others using?
It would amaze me if there was not a product available.
Cheers
Jason.
