RCU Forums - View Single Post - Mach 1 Laser Kit Build
Old 03-28-2009, 08:02 PM
  #74
Pattern One
My Feedback: (73)
Pattern One's Avatar
Default RE: Mach 1 Laser Kit Build
ccpetersen,
Here is a listing of blocks and strips. This should help.
Balsa:
2 pcs: 8 5/8" long x 2 1/8" wide x 9/16" thick. Taper 9/16" down to zero at the other end so it looks like a door stop.
Top blocks, 2 pcs: 9/16" x 2" x 30 1/4". Bottom blocks under fuel tank: 2 pcs: 3/8" x 2" x 8 5/8". Front top blocks above tank: 2pcs 2 1/16" x 8 9/16 x 15/16".
Rear fuse block, 1 pc 7" x 2" x 15/16". Botom cowl blocks, 2 pcs 3 11/16" x 2" x 15/16". Top cowl block, above/around engine: 5" x 3 1/4" x 7/8" taper from 7/8' to zero, looks like a door stop. Filler blocks between F1 & F2: 2 pcs 8 5/8" x 5/8" x 5/16". 2 pcs: triangular stock: 1/2" x 8 3/8".
3/8" Sqaure stock: 2 pcs: 17 7/8", 2 pcs: 12 5/8", 2 pcs: 30 1/2". Tri stock: 2 pcs: 3/8" x 36".
1 pc: 1/8" x 1/4" x 36". Fuse bottom block: 3/8" x 3 1/4" x 15 5/8".
1 pc: 1/4" x 3/8" x 12. The front cowling blocks are 3/8" sheet. Wing tip blocks: 2 pcs: 1" SQ x 8 3/4". Stab tip blocks: 2 pcs: 1/2" x 5/8" x 4".
Hardwood:
Wing Hold Down Blocks: 2 pcs: 1/4" x 3/4" x 3 5/16"
1/2" Hardwood dowel to support wing hold down bolts.
This should give you a good start.
Leo
