RE: possible
You can operate two ESCs in parallel. That is, use a "Y" harness and connect two ESCs to the receiver's throttle channel.
With many ESCs you must disable the BEC in one of them when running two ESCs off one receiver. This is often done by disconnecting the power (red) wire in the ESC's 3-conductor control cable.
- Jeff
