RE: possible
hawkman -
It would help if you explained exactly what it is you are trying to do. Then we could give you better answers.
Are you asking if it is possible to use two ESCs "in parallel" to operate one motor" If so, the answer is NO. If your motor+prop draws more current than one ESC alone can handle, you must get a larger ESC.
- Jeff
