RE: Brillelli 46 Dies on Take Off - HELP
Propstrike,, I don't know anything about your ignition, but I do know on "some" ignitions it could be as simple as needing more ignition battery power, or having the incorrect Spark Plug gap for your ignition's battery,, if your's is a 4 cell you may have to much gap,,
before spending all kinds of money find out if you can run a 5 Cell (6V) pack on the ignition, and make sure you have the correct gap,,
why I say this is my MVVS 35 took 30 or more flips to start, and the power was low at lower RPMs, then I went to a 5 cell ignition pack my problem was solved..
Jim
