RE: What plane can I buy and use my DX6i??
Your Dx6i radio can be used on any plane that uses 6 channels or less. It is a full range radio so it can be used with nitro or large electric planes too. The only other thing you will need is a suitable 2.4ghz reciever (Spektrum or Jr). A plug and play plane usually means that you supply the transmitter, reciever, and battery. A bind and fly plane would need only a compatible transmitter. Hope this helps.-OEMFlyer
