ORIGINAL: subsinker Thanks Pete
I,mm on it. How much running time will one of those packs put out?. I installed 2 9-18VDC motors direct no gear reduction involved. I would like atleasted a good hour running time I hope I can that muck out of it. Thanks Again Pete.
Franklyn Retired Us,Navy BMC.
Franklyn,
Hi from a fellow Navy vet (HM-1). Well, you could do that but I would be concerned about weight. The Lindberg PT's I have had all have had weight management issues (don't we all) I would think it would be better to purchase one battery pack and use that. Tower Hobbies or any reputable hobby shop can help you there. The newest packs have a 5000Mah rating so it would be equivalent to 5 of the radio shack batterys. Here is but one example, there are tons of them to choose from
http://www3.towerhobbies.com/cgi-bin...&I=LXTAR9&P=ML
Using one battery pack would certainly keep the weight to a manageable level and would greatly simplify wiring the old PT up. Not to mention, if you bought a couple of them you could swap them out and double your run times.
Pete
