RCU Forums - View Single Post - Will it fly?
Thread: Will it fly?
Old 04-10-2009 | 12:08 AM
crazychris46dividedby2
Default RE: Will it fly?
nicely built shockdriver. my kinda guy right there. i build incredible amounts of planes. most important things ive learned building things that fly is this. center of gravity is key, i usually build it without the electronics in it and mark the CG. then i test glide it without any of the components on it to see if the components need to be located forward or rearward. then i add them to it. another big issue is making sure theres enough thrust to push it forward fast enough to make the surface area of it create lift. i used to think scratch building planes was so impossible until i just tried it. first one i built i used the electronics out of a blade cx-2 helicopter and used a wing from an aerobird commander, along with a balsa wood fuse with foam board for the rudder and elevator. took it out to the field and guess what? it flew. and it flew surprisingly well. it had great control and lift. i was so entertained by the fact that i build something out of a bunch of parts that i forgot to pay attention where i was flying and tragedy hit. flew it right into a tree. luckily i had a friend with me that helped me spend about an hour throwing things up at it that i got the electronics back. the plane didnt survive but the flight alone was all i needed to realize jut how fun it can be building planes. but id say you did a great job on it. looks like a f-22a raptor to me. not sure if that was your intention or not. but give it a go. if it fails to fly or flies horribly dont get discouraged, use the info as experience and learn from it. and in no time at all youll be doing hat i do, buying planes and looking at them unlike most peope do. with the eye of what if! good luck with your maiden, let us know how shes goes, chris
