RE: a6 intruder from the movie "flight of the intruder"
No, I do not, they went with the build.
The cost is $3000 for the entire set that includes tanks and valves(?), etc.; can't remember everything exactly. You can save a couple hundred dollars if you don't get the "extras" which is what I did. I just got the gear set because I already had valves and tanks and airlines etc. I would also suggest having one valve per retract due to their size, at least that was my plan.
