ORIGINAL: brew2u
LHS owner here outside Austin Tx maidened his GP EMBREE and the gear collapsed 60 ft down the grass runway. Looking at the results inside shows clearly that the gear plywood mount attaches to thin balsa at the sides. He is absolutely furious. I got an EDGE 540T EP with the same design problem on the landing gear, but am glad LHS guy flew his 1st. Will be adding plenty of plywood to the sides of the landing gear mount.
Well I went back and looked at mine that broke, and sure enough it is balsa on the sides there (unlike the firewall that has a layer of both balsa and really THIN ply). Additionally, the THIN ply support that runs between the gear area and the battery tray for strutural support is cut and installed so that the wood grain runs horizontally instead of vertically...what were they thinking?!
