RCU Forums - View Single Post - Tuning question?
Old 04-13-2009 | 10:38 AM
av8tor1977's Avatar
av8tor1977
Default RE: Tuning question?
How's the ignition timing? Advanced timing can cause idle problems. It should be at 28 degrees. An ignition that retards the spark at starting/idle speeds gives the nicest idle. I don't know if the ignition you are using has advance/retard or not.
AV8TOR
