RE: Used Tx buying tips and 9c as entry to 2.4GHz
Man you guys are full of good info. The Super also seems to have a lot more preprogrammed mixes etc.
Electric sailplane with ailerons and flaps is my intention as the next step so I can make use of crow. Right now I don't have one with flaps or spoilers.
So if I understand the antenna thing correctly, the one could run perpendicularly for 30 mm and then the wire could be 'bent' to run lengthwise down the fuse, parallel to the coax of the other antenna, but probably offset by whatever distance (I guess 30 mm). Correct?
Dave
