My su-do-khoi was the same way. I used push rods also. While not as good as pull pull it worked well and I had 45-50 degrees of throw no problem. Never experienced flutter or had any problems what so ever. I used plastic lading gear clamps to hold rod to the side of the fuse. The only problem I had with this setup is when my buddy flew through it. That was kindy of a problem.
