RE: Kyosho HOR
I got the front light wheel weight and the high grip wheel set from ebay.
On the stock white rims, there holes to screw the wheel weights, but not on the black high grip wheel set. Is that normal.
How do you secure the wheel weights?
Do you also need to put foam inserts if using the stock wheels and tires? (Because the high grip wheel set came with it? (Maybe that's why there is no need for screws)
