RCU Forums - View Single Post - throttle, govenor set up problems
Old 04-22-2009 | 10:21 PM
zreimer164
Default throttle, govenor set up problems
OK so I got a Raptor 50 Titan, well this is a replacement because I had a Raptor 30 that I put a OS 50 in and got a longer tailboom and the whole works. I got it set up ok then one day it went nuts, over reved crashed it was bad..... anyways picked up the 50 titan kit, because I just dont give up. But I am having problems setting up the throttle and pitch. I also have a govenor the revmax pro I am using Hitex HS-625 MG on all servos. My transmitter is a Futaba TX6H, which does not have a set up for the 5 point pitch curves. But here is my prob, what is the best way to set up the govenor, throttle, and pitch curves so I dont run into problems again. Thank you !!
