RE: Reusing your planes covering material?
Usually the adhesive stays on the wood when you remove the covering so there is nothing on it to make it stick, plus it will have been through the shrinking process when first applied so you will probably have bad wrinkles that can't be removed. Buy new stuff in the colors of your choice and go from there.
