RCU Forums - View Single Post - Reusing your planes covering material?
Old 04-24-2009 | 01:48 PM
OkadaKeisuke's Avatar
OkadaKeisuke
Default RE: Reusing your planes covering material?
I was afraid of that.
Well, you see, I discovered that 5 cross braces in the tail section of my Sig Kadet Seniors fuse, are loose. Almost as if they were never glued in place. I never even flew the plane yet!
I thought mabey I could get away with cutting away a bit of the covering to repair the cross braces and then just seal it back up.
At this point I am not too concerned about the looks of the Trainer, but I am concerned about it's functionality.
Is there any way I could do this, and use new covering to patch the hole? Or do I have to recover the entire Fuse?
Thanks for any help!!
Noah
