RCU Forums - View Single Post - Tap and Drill set?
Old 04-27-2009 | 09:24 AM
jib
Default RE: Tap and Drill set?
You are not cutting steel, you are cutting at worst, aluminum or fiber reinforced engine mount, often just balsa or balsa hardened with CA, . Either set will be fine. While it's not great, I've been using a HF set for about 10+ years and it's held up on steel.
Jack
