RE: CAP or Extra?
Go to your local home center and see if they have titebond II. That will tell you if the LHS is blowing sunshine your way or not. I think they are just trying to sell you CA.
You can use titebond just about everywhere they call for CA, except for CA hinges, hardening threads in wood, and hardening control surface areas for control horns.
Instead of locking the parts together and wicking CA into the joint, apply a little titebond to the edge of the parts before assembly. Then go back and lay in a fillet for extra strength. If you want to see how a build is done with titebond instead of CA search for RCKen's Pay It Forward PT40 build.
