RE: Flycamone 2 issue
That is my mine gripe with it..I now run it with a battery out side of it or run the power from the mount...The battery on the back is a 800ma taped to the back and will run untill the card is full...If I put on the plane I use the adaptor with a 5v reg to the unit...Have no more problems...
The main problem with the battery failing I found with my cams is that I leave the power switch on, it drains the battery and it wont recover...The Manufature says not to leave it on...
