RCU Forums - View Single Post - how do i can make the tires more soft
Old 05-12-2009, 06:52 AM
adrians3109
Default RE: how do i can make the tires more soft
ORIGINAL: KE4QPF
I have also found that heat tends to soften things up a bit. The heat tends to loosen the molecules in the rubber so they expand a bit. I wouldn't recommend a blow torch, but light heat from a hair drier would probably do the trick.
does this apply only till they are still warm? ...or they will remain like this then even when cold again?
