ORIGINAL: jason
ORIGINAL: rcguy!
ORIGINAL: jason
ORIGINAL: dw_crash
Gents,
So, I'd like to hear more on the tweaks needed to make a nano-joe run. I heard about the bearing preload....what else?
DW_Crash ( an accidental JJ1400 owner that has an engine that works great )
I think once we have engines that run for more than 15 mins/2.5 runs we will know if there are any further problems. Mine is still with JJ at the moment with no signs of it leaving the factory with a sorted preload yet..
Jason
Can you tell me if the 6 month warranty clock stops ticking when a turbine is returned for warranty repair? My guess is you are at least 1 month into the 6 month warranty period? Total time before failure? How many minutes on it?
Dave
It's difficult to know the exact run time on that ECU because the clock starts ticking when you start it and stays ticking until the RX power is switched off. Mine ran for less than 15 mins although the timer says twice that. So run times on this type of ECU don't mean a whole lot.
Jason, (not jamiechip)
Thank You for the reply. I see you didn't answer the question on the warranty clock ticking? Can you?
Dave
