RCU Forums - View Single Post - Hirobo Quark Blade Repair
Old 05-18-2009, 03:07 PM
67shelby
Default RE: Hirobo Quark Blade Repair
ORIGINAL: Balr14
Just use 5 minute epoxy. Apply it liberally. You don't need anything else. You can epoxy the same blades back together 3 - 4 times before they get to ratty to use. I've triedthe laminating method andit worksfor very minor "incidents" ,but it's more trouble than epoxy.
Awesome. Thanks Bair. I'll give it a try. I guess it goes withiut saying then that the blade balance isn't as crucial on the Quark as it is on other single rotor FP heli's huh? If you've glued blades back together that many times the glue itself had to weigh a few grams!
Mark
