i have made a mugi evo plane and use spar also , the weight of mugi plane is 255 gms without anything , and i use 4mm elvons . my mugi span is as per plan 800mm or 31.5 inch . accept elvons all plane in 2mm coro
kindly some one guide me that ,
can i use outrunner brushless motor , if yes then what kv ? i will fix the motor back side not in front .
what prop ?will be good
what esc ?
some one told me that hobbyking is good place to buy , please tell me which motor from HOBBY KING I BUY , i want buy both inrunner and out runner with esc , you people have very good experince in mugi , so kindly guide ,
what kv and which size motor .
is my mugi weight without any thing is ok ?
i am surprise that how the actual plan weight with every thing come out 450 gms
my 1800 mah lipo battery weight is 162 gms .
because i dont have inrunner motor ,
thanks if some one guide me . i am great lover and i will built bigger size also , like 40 inch span , if some have plan for 40 size pls also let me know with thanks and tell what motor will good for that .
tariq
