RE: TT .46 Pro Break In Compression
I had some help out there, they told me to fire it up and go fly. That didn't sound right so I bench ran it for almost 2 tanks first. I adjusted the high speed needle until I got a good transition from low rpm to high rpm. Then set the low needle for a smooth idle. </p>
Do you think I really damaged the engine that much? If I run it rich for a few more tanks will it be ok?</p>
