Old 05-20-2009, 07:04 AM
DonStegall
DonStegall's Avatar
Default RE: The Smasher - Building the Wood V-Tail
The support holders are glued to the base. I just use TiteBond and make sure that any excess is removed. I use a chisel. This is important because the supports will be right against the holder and they need to contact the base for correct registration.
The last picture is a set of the supports. These are some I had already made. I'm going to show you how to make 4 identical pieces, because these ARE critical in terms of the angle.
ID:	1202341   Click image for larger version
ID:	1202342   Click image for larger version
