RE: New JetJoe J-Junior 4lbs turbine
what you could try is a bypass valve. A remote needle valve off a OS 91 is perfect for the job if you have one. Cut the tube between the pump and restrictor and T the needle valve in and return the fuel to the tank. It would at leastsort the over fueling out.
Jason
