RE: xyz cdi
I went back and reset the timing using the method you guys described. I had it set around 15 degrees BTC when I started. When I set it at 28 degrees BTC, it was right where I had started. And at WOT it randomly missfire. I moved it back to about 20 degrees and it smoothed out and ran normally. Any explanations?
Jim
