ORIGINAL: FR4-Pilot
Tx testing ... Tried a JR7202 with the same results - twitching after around 30 feet or so. Appears the Tx is not the cause. Wonder if unwrapping the Rx antenna wire and letting it dangle full length will improve receive signal strength ...
-John
Just flew two packs outside with the Rx dangling full length (25"). It didn't seem to do any worse than wrapped & 12" dangle (default). Still had to point the Tx antenna down for best range (reliable, that is).
-John
