RE: Colco Apache
<font color="#0000ff">ejh1850, welcome!</font></p>
<font color="#0000ff">E-Sky are a long running company that have good quality products (they make the Lama V4 as mentioned above!), they are one of the oldest companies to produce electric helis and have built a good reputation!</font></p>
<font color="#0000ff">there are several helis that are co-axial (i.e. contra-rotating rotor heads on the same axis) and it is worthwhile to have a browse through the many different web sites and magazines</font></p>
<font color="#0000ff">if you're into scale military; there are a couple of companies that also produce a dual co-axial version of the chinook/ sea knight which is very cool looking!</font></p>
<font color="#0000ff">the co-axials are inherently more stable than a single rotor but they tend to lack performance a bit when progressing to Fast Forward Flight but saying that they are brilliant for learning to hover in every attitude (nose in, nose out, etc.) and traning muscle memory</font></p>
<font color="#0000ff">the slight advantage with the E-Sky helis is that they come with a confuser dongle and the shareware FMS flight simulator so you have your practice platform already but if you really feel that money burning a hole in your pocket then there are other more in depth sims ranging from $50 (clearview sim available online) to a couple of hundred bucks; up to you!!!!</font></p>
<font color="#0000ff">other thing to remember is that <u>most</u> co-ax's are really intended for indoor use only so be aware you will probably need a bit of space, especially when first flying!!!
hope this helps, any more info you need just ask! all of your questions answers can be found on these forums with a little looking!
Matty )<>}}}}}}}]@></font></p>
