RCU Forums - View Single Post - Problems with inverted 2-stroke engine
Old 06-11-2009 | 01:16 AM
ameyam
Default Problems with inverted 2-stroke engine
Dear All,
I am currently flying a Phoenix Topstar 60 without cowl on a OS75AX 2 stroke. As per the design of this plane, the engine is mounted inverted.
In the recent, I have had a lot of issues with tuning the engine. It either cuts in hower or in straight and level at 50%. We have tried manuplating both the needle as well as the low end screw to no avail.
Someone of the field mentioned that 2-strokes are difficult to tune inverted. Is this the case? Should I mount the engine at 90 deg? (will have to modify the firewall for the same)
Ameyam
